LabVIEW Embedded
LabVIEW Blackfin failed to generate C code...
I have some troubles building an application with LabVIEW for Blackfin.  I figured out that is related to the "Tones and Noise.vi" vi.  I tried to build an application containing only this VI with all inputs connected and I got the same message "Failed to generate C code for project c:\..." and the details windows is empty.
What's wrong?  Is there a place to find a list of VIs that can't be used with Blackfin?
Regards
Patrick
(7,179 Views)
I just found out that the problem occured when I select to optimize the code for speed.  Are some VIs prohibiting using optimization?
Patrick
(7,168 Views)
Patrick,
I was able to easily reproduce this.  I will be working with R&D to figure out what aspect of this behavior is the bug.  I will post the Corrective Action Request (CAR) ID once I have this information.
Thanks for bringing this to our attention.
-Mark
Mark
NI App Software R&D
(7,165 Views)
Patrick,
I have submitted this problem to R&D with CAR ID 175692.  Thanks, and plese let me know if you need anything else.  Have a great weekend!
Sincerely,
Chris G in AE
(7,109 Views)
