LabVIEW Embedded
LabVIEW Embedded for ARM build fails
Oh,
the last Link is for Labview 2009.
The right solution is this file:
http://joule.ni.com/nidu/cds/view/p/id/1314/lang/de
Message 11 of 14
(4,633 Views)
aminat,
    I'm glad that everyone is solving their problems but if you have a new issue please start a new thread. This is the most efficient way of getting support from the whole community. The original question on this thread was solved a long time ago and was set to "Solved" so not a lot of people monitor the thread anymore. Just words of advice.
Message 12 of 14
(4,612 Views)
Hi! recently,I do some job in LabVIEW Embedded Module for ARM Microcontrollers in version 8.6. When I want to run my project. but there is an error after application started which is Failed to script uVision build tools. then.i select "show Keil uVision" from Tools\ARM tools...and it also failed. so, i don't how to solve this problems.
Message 13 of 14
(4,498 Views)
Tim,
        It's proper forum policy to start a new thread if you have a new issue. If you are having the exact same issue as a thread then its fine to reopen the thread by posting to it. We are going to need more information before we can even start to troubleshoot.
1) What exact compiling error are you getting? Did it have a number associated with it or just "Failed to script uVision build tools"?
2) Can you deploy a shipping example like Blinky just fine?
3) What hardware are you using? MCB2300?
Not being able to open "show Keil uVision" from Tools>>ARM Module makes me think that either you don't have uVision installed or activated or your ARM Module installation was corrupted.
4) Can you open uVision by just going to Start>>All Programs>>Keil uVision ?
These answers assist me in supporting your issue better.
Message 14 of 14
(4,489 Views)
