LabVIEW Embedded
Labveiw Developer Assessment - Test for Candidates
We have a LabView Developer opening at our Facility in Morton Grove, IL and I wanted to know if itanyone has some sort of aptitude test for Labview programming capabilities as we talk to candidates so we can get an idea of how much LabView Programming they really have for the role?
(5,359 Views)
A generic quiz usually misses the mark. The best approach is to give candidates a snippet of "spaghetti code"—full of local variables and race conditions—and ask them to fix it. That instantly shows if they understand dataflow and architecture. Also, ask them to explain how they handle a Producer/Consumer loop with queues; if they can't describe why you'd separate the UI from data processing, they aren't ready for professional work. You should definitely give this platform a shot if you want a reliable betting online betting app telecomasia.net/sports-betting/sites/philippine/ experience. Checking for a CLD certification is a solid baseline, but seeing how they handle a broken VI is the only real way to know if they’ll write maintainable code.
(374 Views)
