LabVIEW Embedded
Lost all EIO
I have somehow lost all the EIO for the targets that ship with the CD. I have reinstalled all the software, to no avail. When I drop an EIO block into a VI, I get errors relating to implementation VI. When I open the associated GCode VI, I notice a broken arrow, and the following error: Inline C Node, not supported for current target. What have I done?
Also, in the Edit EIO devices, the EIO classes under cmd565 are not there anymore.
David
(8,357 Views)
Does CTRL+SHIFT+RUN fix the issue? What if you delete the node and then undo that deletion, is the arrow still broken?
P.J.
(8,349 Views)
It turns out that this problem is fixed if you add any VI to the block diagram and delete it. It as known issue (listed in the readme) and we are investigating the cause.
P.J.
(8,334 Views)
