LabVIEW Embedded
MCB 2300 SD - remove card error
Hi everyone,
I have a problem with SD card on my MCB 2300 ( uC NXP 2378 ). I use SD card to collect data wrom A/D converter. Data is stored on my card every hour.When I remove SD card from its slot and after a smal period of time put it into slot , my program get stuck. Do you have any ide why this happen? Here is a small prat of my application responsible for writtiong on SD card:
(6,591 Views)
Hi
What does it means "get stuck"? Is there any error message that I could refer to?
You can look on those links for additional informations:
http://decibel.ni.com/content/docs/DOC-6254
http://digital.ni.com/public.nsf/allkb/4998923F82F1F52C482573590058C667?OpenDocument
Regards
Barbara
(6,578 Views)
It means something like blue screen in Windows. I get no error information. My program stops. I happen in this order:
- I save some information on SD card
- I remove card from the slot
- I insert card back to the slot
- I try to save data on SD card egain ( now the program stops )
(6,573 Views)
Hi
If You could attached a log file with error description. You can find clues how to do that on web: http://digital.ni.com/public.nsf/allkb/7E9EBE4CA3B6DCE786257633005E7121?OpenDocument.
This will give us detailed informations about what exactly goes wrong.
Best regards
Barbara
(6,523 Views)
