LabVIEW Embedded
Not able to duplicate timed loop example?
Also monitor the error wire if you can during debug so we can see if anything is happening after that first read.
Message 11 of 17
(4,169 Views)
crashed...let me clean up a bit, make sure none of the build specs have changed and then restart everything to get a clean load.
Back in a few...or maybe even in the morning.
Thanks.
Message 12 of 17
(4,168 Views)
ran it again...it crashed...(will explain in detail tomorrow).
Ran the example again looking for a way to monitor the error variable value with a probe...but need some help with how to do diagnostics...(just create an indicator and then rebuild?)
Thanks.
Hummer 1
Message 13 of 17
(4,165 Views)
You need to enable debugging in the Application properties (in the Application Information category) and choose the appropriate debug method (in the Advanced Debugging Options category). I use my JTAG connector because you can see the block diagram in highlight execution just like you would for a VI on Windows. I use this type of debugging along with probes to see what the code is doing.
If you don't have a JTAG or can't get the TCP or Serial debugging to work, then programmatic things like blinking an LED if there is an error can be helpful.
Message 14 of 17
(4,160 Views)
We have a JTag, but haven't used it yet...looks like it is time to break it out.
Thanks.
Will post again when we have done that.
Hummer1
Message 15 of 17
(4,158 Views)
Hummer1,
       Here is a great help file on setting up Blackfin application for debugging and your options (http://zone.ni.com/reference/en-XX/help/371653C-01/lvblackfinhelp/bf_debugging/). Check it out when setting up your application later.
Message 16 of 17
(4,151 Views)
The JTAG devise is attached but we are trying the RTC periodic example.  It fails when the ezToggleLED.dll is changed to the ToggleLED.vi...we get a KernelPanic.  I posted this on another thread...Thanks.
Hummer1
Message 17 of 17
(4,128 Views)
