LabVIEW Embedded
Open Process Session.vi
Hi
I am trying to create an unix console appliacations in LV 8.2 using cygwin 1.5.25. However when i am trying to build the applications it is giving the following error (see image).
"Failed to build executable!
Error message:
Error output:
Can anybody help me to solve this problem?????/
(7,937 Views)
Hi
I am trying to create an unix console appliacations in LV 8.2 using cygwin 1.5.25. However when i am trying to build the applications it is giving the following error.
Error code: 7
Error source:
File/Directory Info in Emb_Utility_AppUpdate.vi->LEP_unix_ScriptBt.vi->LEP_unix_Build.vi->LEP_unix_Build.vi.ProxyCallere\Console_Application_1\Console_Application_1.exe'. File not found.>LEP_unix_Build.vi.ProxyCaller
(7,930 Views)
This tutorial might help: http://zone.ni.com/devzone/cda/tut/p/id/5412
Note that you need to change your system path variable to include the Cygwin/bin directory. Also, when you install Cygwin, choose the DOS/text radio button.
Michael P
(7,918 Views)
Hi
I get the same error message if I try to build the Filter-Example of the following tutorial: http://zone.ni.com/devzone/cda/tut/p/id/5412
Error Message:
Error Output: Open Process Session.vi
I added the system path variable "C:\cygwin\bin" and I also choosed the DOS/text radio button.
But at the installation of Cygwin I didn't found a package called "tclck" although this name is mentioned in the tutorial.
So I installed the tcltk-package and now I get the error message above.
Urs Kuenzle
The System:
LV 8.2
Win XP
(6,995 Views)
