LabVIEW Embedded
PDA deploy using TCP/IP
Can we deploy LabVIEW PDA/LaBVIEW Mobile through TCP/IP, ethernet?
Thanks.
(6,844 Views)
If you can see the PDA device on your computer  through the manufacturers software, then I would imagine that you could deploy to it.  I've never heard of any PDA that works this way, but there is a lot out there and they do things differently.  Have you tried it without success?
(6,829 Views)
I used FTP and was able to connect to the device snd deploy the exe file.  However, I am not sure how to run the application remotely after deployment.
(6,810 Views)
You would run the VI from the PDA.  The executable should be sitting in your file system and you can just select it and run it on the PDA
(6,793 Views)
