LabVIEW Embedded
Please, help me to porting to Luminary Stellaris LM3S9B92
Dear all,
i have a evaluation board Stellaris EKK -LM3S9B92 and i want to develop a web-based system with LabVIEW.
I have following the guide http://zone.ni.com/devzone/cda/tut/p/id/6994 and similar without any succes.
PLEASE help me!!!
Thanks in advance
(6,405 Views)
Hello andcell,
what do you mean by "no success"? Do you receive some kind of an error?
Antonios
(6,396 Views)
(6,395 Views)
Dear AV
yes, i have read this post but i think that something is missing because don't work.
I had do the following steps in a fresh installation of Windows XP pro:
1) Install Labview for ARM 2011
2) LabVIEW automatically install also Keil uVision4
3) i had create a new project and follow step by step the instructions described on http://digital.ni.com/public.nsf/allkb/5E4FE2C9F0E061EF862575D30051131Eù
4) go on uVision and change the interface for debug and download to ICDI
DONT'WORK and after download the code (a simple while loop with 100ms of timing ) target could not more programmed, i need to unlock it with LM Flash Programmer
So i go in uVision and:
1) i had manually change the target to LM3S9B92
2) install new stellarisware (8049)
3) update the pin_map.c
4) update startup.c
5) update RTX_Config.c
6) create (in the while cycle) a simple on-off of the led on the EVboard connected to PinD0
7) pin dont' blink but is it possibile to reprogram the evboard without unlock it with LM Flash programmer
What can i do?
Andrea
(6,389 Views)
