LabVIEW Embedded
Porting to ARM LM3S811, PWM and serial port issues
Read my previous post: http://forums.ni.com/ni/board/message?board.id=420&thread.id=1996
I am having problems again, I have corrupted sent data throught serial port 0 when using the NI serial driver on the LM3S811. I also get error code -1073807339 when reading that data, inside labview with VISA, sent from my ARM to my PC.
I am thinking that the timings might be wrong, but I don t know where to look for  baud-rate divisor for UART0. The 3S811 is Xtal 6Mhz, not 8Mhz like the 3S8962.
I also tested the PWM on a scope and the frequency dosen t match, if I ask for 1kHz I get around 666Hz. Seems like setting the Xtal to 6Mhz in uVision is not enought.
thx
Lukasz
(6,628 Views)
Hi Lukasz,
My collegue will be posting to your other post shortly.
Claire Reid
(6,597 Views)
Accepted by topic author L._Andrzejewski
Ok, here is the solution.
Open "startup.s"
Goto line 193:
        ; set the system clock to run at 50 MHz
        ; SysCtlClockSet(SYSCTL_SYSDIV_4 | SYSCTL_USE_PLL |
        ;                SYSCTL_XTAL_8MHZ | SYSCTL_OSC_MAIN);
        LDR        R0, =0x01C002C0
        BL        SysCtlClockSet
        B       __main
Replace R0, with the right values found in "sysctl.h" line 236:
in my case set the crystal to 6Mhz which is "0x000002C0"
PWM timing is restored and serial port works fine now.
(6,573 Views)
