LabVIEW Embedded
Problem firing blackfin timed loop using external firing
Hi there,
I have problems using timed loops, with an external firing source! The callback only go to timed loop the first time, and then it stops!
If I use the same callback with: "True = Data-Ready" and polling data-ready in main, it gets called several times, so it's a problem in timed loop configuration.
I use Timing Source, equal to callback timed loops example (the example works fine) I don't understand why sometimes I get the word "scans" in the loop, othertimes I get "ticks", or "ms" If I use internal timing, but that is obvious...
Thanks in advance,
P.S. - the idea is to use two parallel timed loops (one fired by callbacks, other by internal timing)
António Veríssimo de Freitas
Universidade de Aveiro Student
(6,354 Views)
Hi there,
Isn't this problem usual?
(6,311 Views)
