LabVIEW Embedded
Programmatic Discover C series modules in any compactRIO System (with or without EtherCAT) connected in a network: position and model
This application is an example of programmatically discovering C series modules present in any CompactRIO Scan Mode system connected in a network. This application works properly with both systems: only one cRIO or cRIO + EtherCAT.
This application should run in a Windows target and to work properly some requirements must be followed:
  • The versions of drivers installed in cRIO should be the same that installed in Windows target;
  • The I/O Variable Remote Configuration Web Service must be installed in cRIO:
Message 1 of 1
(5,116 Views)
