LabVIEW Embedded
Read From Binary File doesn´t work on MCB2400 in LV2009 Embedded ARM
That's strange, I would have expected that to work.   Are the values "wrong" in the sense that the byte order is swapped?  If so, we can swap the bytes in G code:
Message 11 of 14
(4,492 Views)
I admit there is confusion around byte order terminal on embedded targets, but LabVIEW is actually doing what it is suppose to do:
(I rather like the string version)
Amin, regarding embedded targets I have to admit I was a little sketchy:
They accept only BIG-ENDIAN!
Message 12 of 14
(4,479 Views)
Ok Thanks !
In this case I have to think about if I transform my bin files always to big-endian or I still use the old workaround.
But I think if I use the workaround with big-endian the hardware usage will be a little bit less, so this would be the better one.
bye & thanks
amin
Message 13 of 14
(4,459 Views)
OK,
now made it like this:
And it works fine.
I think it´s better to convert the bin on the PC, to get more performance on the hardware.
bye & thanks
amin
Message 14 of 14
(4,455 Views)
