LabVIEW Embedded
Redboot download aborted
Couldn't get LEP_ecos_RedBootDownload.vi to download my application. Used hyperterminal:
RedBoot> load -m ymo t
CCC*** Abort! Attempt to load ELF data to address: 0x000008054 which is not in RAM
xyzModem - CRC mode, 1(SOH/1(STX)/0(CAN) packets, 5 retries
Any suggestions?
Richard
(8,132 Views)
Richard,
Is the linker definition file (LDF) correct for your eCos target? It looks like RedBoot is trying to load your ELF binary into memory ranges it shouldn't.
If your LDF file is wrong, your target documentation should include a memory map, showing RAM and ROM memory ranges.
Good luck!
Andrew Callan
(8,125 Views)
