LabVIEW Embedded
Run startup fom Xfce Desktop Environment
Hello, i want to ask if I can run startup fom Xfce Desktop Environment. I work with cRio-9038 with NI Linux Real-Time and embedded UI. In Xfce enviromet is located file here c:\ni-rt\startup\startup.rtexe but i don't know how to start the file. Is it posible run just after reboot like startup or can I do it somehow again in enviroment? Thank You for answer.
(5,477 Views)
Hello!
Yes, you can run startup executables with your RT VI front panels serving as the embedded user interface on Xfce, the same as building other startup RT EXE without a UI. Here's some helpful resources:
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(5,281 Views)
