LabVIEW Embedded
SD Card save data
I am using sbRIO 9636 which has a SD Card. How to store and access data to and from SD Card using LabVIEW?
I am acquiring data from Analog IO and would like to save 30mins of data to SD Card and then transfer the stored data of last 30mins from SD Card to host either using network stream or webservices.
TIA.
CLD
(10,109 Views)
Hi lvrat,
I posted on another thread with a similar question. You may find it useful.
Best,
Tannerite
(10,107 Views)
Thanks Tannerite for the infomation.
My understanding is that I acquire the data from FPGA (hybrid setting combination of scan engine and FPGA directly) and then on RT VI I use Invoke node method to mount SD Card, open file and write the data to file using the SD Card path. Will try and see how it works.
CLD
(10,094 Views)
Error occurs on Mount SD Card invoke node in RT VI, any suggestion on what is causing the error? I created a FPGA VI to acquire temperature and RT VI to store the temperature to SD Card. Attach is the RT VI and the error image.
CLD
(10,087 Views)
Did you ever figure out what was causing your issue?
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
(7,949 Views)
