LabVIEW Embedded
Sd card error on LM3S8962
Hello !!
We had a program almost done and debugged which worked on the LM3S8962 kit but without particular changes on the VIs the writing on the sd card stopped to function. we tried a very simple vi to test it and received the "Open File Error Code 6" while writing which means that the sd card is full but ours was empty, and "Open File Error Code 7" while reading.
We thought of a problem with the kit and tried with another one we have but the result was the same.
I joined the snippet but there's nothing special on this VI.
If anyone met a similar error or have an idea of where it could come from we would be glad to gear it !
Tomasss
(6,454 Views)
Probably specifying the file path to the first Open/Create/Replace vi would fix the problem.
(6,359 Views)
