LabVIEW Embedded
Servo motor control using MCB2300 and Labview
Hello Everyone,
I have to drive servo motor using MCB2300 board and labview. I am new to LabView as well as MCB2300 board. I understand that I have to generate Pulse to control the servo motor.
I have gone through some of the post but could not find something useful.
I need to do it asap, a fast and eloborating answer is much appreciated.
Thanks is advanced.
Message 1 of 8
(8,926 Views)
You need to install Labview for ARM to get proper examples of MCB2300 PWM varying.LPC2378(the ARM controller in MCB2300) has 5 PWM output channels.You will get PWM examples for MCB2300 which will vary the PWM as per your code.
You might require an FET to drive up the current to drive the Servo as we experienced this issue of motor not responding to our PWM.LPC2378 doesn't have enough current driving capability.I may share the IC details if you are interested to this solution.
Message 2 of 8
(8,913 Views)
Thank you very much for your response. I have already installed LabView Embedded Evaluation version. I already had LabView 2009 Student License on my machine. I am not able to find the example codes. Can you please guide me, where it might have copied the example codes?
Also, please shed some light on the alternate method you metioned.
Message 3 of 8
(8,909 Views)
LabVIEW embedded is different from LabVIEW for ARM.
Message 4 of 8
(8,905 Views)
Please download LabVIEW for ARM evaluation form http://digital.ni.com/express.nsf/bycode/exfzr4. This includes Keil compiler too. Once you install it,you can search examples from LabVIEW example section.
Message 5 of 8
(8,902 Views)
I don't know if this will help you, but think about this tip:
On the back of my (digital-) Servo package there was some data written (see attached image).
You've heard of PWM (Pulse Width Modulation)? If not look it up in
wikipedia / microcontroller.net / (if you speak german) http://www.rn-wissen.de/index.php/Servos or google
The description of the Servo says that I have to send every 200ms +/- 1ms a positive (+5V +/- 1V) signal with a length depending on the angle I want the Servo to be set. The Signal is coded in conjunction to time, which means, as longer the Signal as higher the angle is. The Signal range is in between 70 to 240 ms (with my servo and not exactly). The Signal must repeated every 200 ms like I said before. I don't know, if you understand C but here is a function I wrote, which works fine for me:
void set_Servo_0(uint8_t angle)
  DDRA |= 2; // Specific Port declaration for my µC (Atmel)
  uint8_t tick; // a var to count how often I send my Signal
  for(tick = 0; tick < 2; tick++) // loop to count -> send Signal three times
    if(getStopwatch1() > 200)  // getStopwatch is a libary specific function to measure time in ms steps
      PORTA |= 1;  // port high
      sleep(angle);  // angle comes from outside the function, it is a parameter for this function. Sleep for this time with port high = pos Signal
      PORTA &= ~1;  // then pull down
      setStopwatch1(0); // reset the timer
  mSleep(250); // Finally I have to wait for this time (in ms) when I send different angle parameters one after another, to let the whole system
                      // (µC + Servo and rest of program) to settle down, else I will loose signal steps due to incorrect timing (not nice, but works).
This function gets the angle as Integer from 7 to 24 and puts the Servo in corresponding position one time.
Maybe You can adapt it, good luck.
Message 6 of 8
(8,857 Views)
Hi again, made some modifications to the function:
uint8_t lastangle; // save value of last angle
void Serv0(uint8_t angle)
  DDRA |= 2;
  uint8_t tick;
      PORTA |= 1;
      sleep(angle);
      PORTA &= ~1;
      setStopwatch1(0);
  // here comes the change: if the difference between the last angle and the current angle exceeds 8 Steps, the delay will be greater to give the
  // Servomotor enough time to move to the desired angle (see moving speed specs in image; my servo is driven by stabilized 5V)
  if(angle - lastangle >= 8 || angle - lastangle <= -8) // compare the Variables for their difference
    mSleep(300);
  else
    mSleep(240);
  lastangle = angle; // Huha! 🙂
Thanks for the inspiration!
Message 7 of 8
(8,845 Views)
Hello, tlwm. you have got through the servo control ARM? Could you show your project? thanks
Message 8 of 8
(7,687 Views)
