LabVIEW Embedded
Unable to compile showing the error (Error 7)
I am doing a project for data logging using cRIO 9004 for that when I compile I found following problem
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at List Folder in nirviEIOImplementation_getModGenPlugIn.vi->nirviGetModInfo___nirviEIOImplementation_modGen.vi->nirviGetModInfo___nirviEIOImplementation_modGen.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488:  Nonexistent GPIB interface.
D:\i.lib\LabVIEW Targets\FPGA\cRIO\shared\nicrio_StockModGens\cRioStock_io_modGen.llb
Can anyone help please......
R@NI
RohitS
Message 1 of 1
(4,017 Views)
