LabVIEW Embedded
Using LV / LV-Embedded with Rabbit boards & Dynamic C
Has anyone tried using LV or LV Embedded  ported to a RABBIT board (that may use Dynamic C) ??
I'm starting to contemplate/experiment with this combination and
would like to discuss other people's experiences and
maybe pick up some guidance!
(7,550 Views)
I did a bit of research on Dynamic C today, and I'm doubtful that it would be compatible with the generic C code generated by the LabVIEW C Code Generator. I recommend that you research the differences between Dynamic C and C. The LabVIEW Embedded Porting Guide lists the steps required to create a new LabVIEW Embedded target, so use that as a resource.
Michael P
(7,543 Views)
Thank you Michael... This is the type of information I'm interested in.
Not knowing the intimate details yet, I would assume (there's that word!) that maybe I could bypass Dynamic-C totally and have everything done via LV-Embedded.
I will review the recommended manual and reply IF I get it working...  however, any further comments are more than welcome.
Steve
(7,529 Views)
Steve,
If you can find a way to "bypass Dynamic-C" and build a C application, this would be a good start in proving out that you can run LabVIEW-generated C code on the device.
Michael P
(7,524 Views)
