LabVIEW Embedded
Using Labview Embedded for Blackfin with BF537 Kit and AD7266
I am using the LabView Embedded Module for Blackfin, and within the example files is "AD7266 Acq.lvproj". The description states that:
"This example shows how to sample the input data from the 7266 ADC add on evaluation board using the BF537 EZ-KIT.  The sampled data is processed to calculate the estimated input frequency, and the front panel is updated using JTAG debugging."
However, according to an applications engineer at Analog Devices, there is no such "7266 ADC add on evaluation board" which is compatible with the BF537 EZ-KIT.  The only eval board, the EVAL-AD7266CBZ, is only compatible with the EVAL-CONTROL BRD2.  Does anyone know what hardware setup this example file was intended for?  The drivers for the AD7266 are built into the Blackfin LabView module, and I would really like to be able to test these without having to design and spin my own board.  Any ideas would be greatly appreciated.
Anthony
(7,884 Views)
Hi Anthony,
The AD7266CB is the evaluation board used in that example, along with a SPORT to 96 pin adapter, which allows it to connect to the EZ-Kit.
Michael P
(7,877 Views)
I'll give it a try, thanks!
-Anthony
(7,873 Views)
Hi Micheal P!
Can i design a circuit using AD7266 IC seperately. How i can connect detail pin AD7266 to ADSP BF 537 EZ Kit lite. Could you show me some reference for my designing?
Thank in advance!
Do Van lam
(7,408 Views)
Hey Do Van Lam,
All the circuit information can be found in the Analog Devices website at AD7266:  Differential/Single-Ended Input, Dual 2 MSPS, 12-Bit, 3-Channel SAR A/D Converter
Hopefully this helps!!
Aashish M
CEO
TransferFi
www.transferfi.com
(7,379 Views)
