LabVIEW Embedded
VISA read also reads carriage return
I am using visa-read block to read some RS-232 connection.
whenever i send a message through VISA-WRITE, i read back the "Carriage-return"
for example, i send:
<some command>
i recieve:
;<some respond>;
if i send out several lines i get the same number of <CR> in return. i cant get rid of it.
could you help.
thank you.
(3,989 Views)
Hi moranEng,
This sounds like expected behavior to me for our VISA-WRITE and VISA-READ VIs.
Can you explain what problems this is currently causing by reading the carriage-return as well?
Additionally, here is a link to a tutorial page we have regarding Termination Characters in NI-VISA.
Tyler C.
Technical Support Engineering
(3,954 Views)
