LabVIEW Embedded
Will embedded arm module work with vision module
Will the vision module create code that can be used for the ARM cortex using the embedded module?
thanks,
(5,953 Views)
Hi tobor,
Unfortunately the VIs in the Vision Module will not work on our LabVIEW Embbeded for ARM targets.  It will, however, work on our RT targets like the sbRIO and cRIO.  What is your application?  Will either of these work for you?
Justin Parker
Product Support Engineer
(5,940 Views)
