LabVIEW Embedded
ad7476A and device buffer size
Hi, I'm using the BF Analog Read ad7476a vi (modified)!
But I can't get the size I want to the filled by the buffer..
Somehow I think the buffer is limited to an 128 elements array, but I defined it with 256, when I show the initialized array it only says I have 128 elements.. allthough using the array size function it shows 256..
If this is a limitation by blackfin, please tell me the best way to build an array with progressive buffer reads..
P.S. - I need a 10Khz sampling and a lots of samples to the filled into an array, or Real Time Calculations, but I don't know how to do it, please help me!
Thanks in advance
António Veríssimo de Freitas
Universidade de Aveiro Student
(7,430 Views)
What is your version of LabVIEW and BlackFin module?
(7,399 Views)
Accepted by topic author freitas
Hi there:
I discovered the problem.. the 128 size is a parameter that can be changed when "Configuring Target - Debug Options" (ADSP-BF537 in my case)!
(7,311 Views)
Hi guys:
I need your help again, here is the problem.
I'm using AD7476A via SPI using circular buffer, the problem is, I want to be shure that whenever I read a subbuffer (after callback), I don't lose any data from the input signal, but using debug mode I can't know because the refresh rate is too slow..
Please look at my code ant tell me this is possible, I will need much higher refresh rate about 50KHz!
Just one more thing, I need to use several ADC's, I know how to config each one, but how to make them work at the same time?
Thanks in advance
(7,254 Views)
