LabVIEW Embedded
blackfin EZ kit lite bf537 code to blackfin-537 phytec board
Hi
I am using  EZ kit Lite BF537 eval board to develop my application and  i was able to develope the  application in reasonably fast time compare to the  C based programming
now i need to move this application form Evaluation board to custom target board ->PHYTEC Phycore BF537
 details of the board is
http://www.phytec.com/products/sbc/Blackfin/phyCORE-Blackfin-BF537.html
i would really appreciate if somebody shares there idea or experiance on this issue.
thanks
 Shridhar
(6,564 Views)
Hi shridharj,
In order to use the LabVIEW Embedded Module for Blackfin on the PHYTEC Phycore BF537 platform, the VDK (ADI's kernel) support needs to be working on the device.  It doesn't look like the PHYTEC Phycore BF537 currently supports the VDK.  From the Web site you posted, it states "VisualDSP++ Kernel (VDK) (Coming Soon)" at the bottom.  You may want to contact Phytec in order to ask if this has been completed yet.
After you get the VDK support, you would then need to modify the LDF file in order to get LabVIEW working.  See this article for more details.  (Deploying a LabVIEW Embedded Module for Blackfin Processors Design to a Custom Target)
I hope this helps,
Kevin S.
(6,547 Views)
hi kevin,
thanks for the reply
here is few details
i spoke to one of the engineer in Phytec to confirm the VDK support answer is yes.
 i went through  the link that you mentioned , i am still not sure which section i have to change.
thanks
Shridhar
(6,534 Views)
