LabVIEW Embedded
blank Target Build Settings
hello folks,
I have some knowleadge with the MPC555 processor in the MatLab RealTime Workshop -- but iam currently trying to get into the embedded Modules for LabView.
I will try to build a little vi (something like a+b=c)  within a "Blank Target - Template". Once thats done i need to configure the Build Specifications to incorporate with my Compiler, Linker and so on -- i hope that will bring me to some sort of flash or ram imagefile.
but the "Build Specifications"-Window doesn´t fully display all entry fields -- see the picture.
* do i need those fields?
* what are they used for?
* any workaround known?
I will happy for all hints on that
iam using Labview 8.5, a MPC555 will be my target (so the Codewarrior is the Compiler)
bye arne
(6,491 Views)
Hi Arne,
One option is to open the dialog plug-in VI and scrolldown on the front panel a little, then save the VI. This will change what you see in the build specifications window.
Another option: Create another build specification Category page using the Target Editor. If you plan to add several configuration options, this step would probably be best.
Message Edited by Michael P on 02-12-2008 10:23 AM
Michael P
(6,485 Views)
