LabVIEW Embedded
change font size in write to OLED for lm3s8962
I'm would like to increase the font size that is displayed on the OLED screen with the lm3s8962. I am aware of the write to string vi. This subvi calls a c function, which I assume contains within it the stellarisware c code for writing a string. I've done some minor programming using KEIL, and now that at the code level, you can specify the string length and height, but I don't know where to access raw c code that the subvi is calling, in orDer to modify it. Any thoughts?
(5,865 Views)
Hi RTom,
You could write your own C code and then use a wrapper and import it into the example.
https://decibel.ni.com/content/docs/DOC-9078
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
(5,855 Views)
