LabVIEW Embedded
change output pins to input pins on Keil MCB2300
I have a Keil MCB2300 setup and successfully running w/ LV2010. I want to know how do I change the digital pins from outputs to inputs. LabVIEW defaults to 7 outputs and 1 input, but surely I can chan;ge these. The Keil schematics just label the pins as digital w/out designating input or output.
thanks,
jason
(6,172 Views)
Jason,
I found a document that I think may be helpful in configuring your inputs/outputs. It details how to create new I/O items for ARM targets which is what I believe the Keil MCB2300 is. Try following the steps in this document.
http://zone.ni.com/reference/en-XX/help/372459C-01/lvarmhelp/arm_eio_creating/
-Nick-
Nick C | Software Project Manager - LabVIEW Real-Time | National Instruments
(6,161 Views)
Sorry,
I should clarify. In the 2nd image above pins 2.0 through 2.7 are already available in the LabVIEW Project manager under "Available Resource." However, I want to access the other digital pins (pins 3.0 through 3.7) How can I add these pins to the list of available resources in LabVIEW?
(6,150 Views)
