LabVIEW Embedded
connections for crio
pls send me connection diagram for ni compact rio,
(7,391 Views)
Hello Srimi,
Can you please tell me which cRIO you are looking for? What connection diagram do you need? Correct me if I am wrong, is it for the controller with the chassis?
LabVIEWGuru
(7,376 Views)
thanks for ur reply.
i'm using crio 9074, and at present i need connections in both fpga mode and scan mode.
for different type of inputs.
just tell me where to place adc etc in that chassis.
(7,356 Views)
(7,355 Views)
also please tell me how to find out dsp module,in the installed files.
(7,348 Views)
please reply to me as soon as possible.
 i'm using RT controller with chassis,it is 9074.
  pls send me simple block diagram for giving a sine wave i/p from a function generator,and to watch the output on labview.
also tell me which components i've to use ,to make this
among 9403,9205,9265,9263.
i know upto how to configure the controller.
(7,328 Views)
