‎03-13-2009 01:31 PM
CRIO 9014 runs a logging application. LVRT 8.6 writes a small (45KB) data file every 1 minute to the 2GB Kingston Data Traveller USB stick at U:. I find that after about 3 hours (about 180 files) the logging stops. If I delete files, the logging will begin again until the stick is "full". However, 2GB/45KB should have room for >44K files. Any ideas?
thanks
Jim
‎03-13-2009 04:04 PM
‎03-17-2009 10:57 AM
Albert
Under the worst conditions the spec would allow 65K entries/13 entries per file to accomodate long filenames or >5000 files, unless I am badly misunderstanding FAT32 specs.
‎03-17-2009 02:06 PM
‎03-17-2009 03:06 PM
I believe I did misunderstand. Too many files for the root. Build a subdir and write to the sub. I will try in a few days and respond.
Thanks!
‎03-26-2009 09:47 AM
Albert, My Friend
You are Brilliant! A subdirectory will hold many more files than the root. Previously I could get only about 3 hours of 1 file per minute, now I have run overnight, 12 hours with no problems.
Thank you!
