LabVIEW Embedded
data logger
Hello
I'm quite fresh with compactrio. I try todesign the embedded data logger system to measure the voltage in solarenergy car. The compactriomust stand alone without pc and save the data in the real time controller.
I need The compactrio can wait for an operator start command from apush button and stop when the operator pushes the button again. I know the compactrio canauto run when the power on or reboot but I want to know other methods toachieve this function.
I usethe crio-9022, ni 9104, ni 9201, ni 9263
Best regards
Andy
(7,312 Views)
Hi
Autorun works OK
only in your program in the rio you should check buttons to determine when to start logging.
greetings from the Netherlands
(7,304 Views)
You could implement a digital trigger by reading a digital line ( push button ) and react when the button switches to true.
(7,288 Views)
I apologize, I see now that you have an analog input module, however the same method applies, just react when you read a voltage on the line ( for example your push button could be a switch).
(7,284 Views)
