LabVIEW Embedded
debug or runtime
I am running an executable which will open a DOS window to run and the executable will produce a .log file.
I am using a “Call executable” in Teststand 2.0.1 in Windows 98
When I run the full sequence in Debug mode, with no interference or break points each time the executable is run(part of a loop reading a changing voltage) the log file is made.
The problem is when it is run a runtime the log file is not made.
Any suggestions?
Simon
Message 1 of 1
(6,113 Views)
