LabVIEW Embedded
error 1073807339
I am getting a error 1073807339 at VISA Read. Can you please help me.
I am attaching the file.
Thanks in advance
(16,381 Views)
Without knowing what hardware you are using, your wiring setup, nor what you are communicating with, it will be difficult to provide specific advice.  However, the error number you are receiving is typically associated with a timeout indicating that the VISA Read function did not receive the requested number of bytes in the time you allocated to it.  Several simple mistakes can cause this behavior. Generic debug information below:
Why Do I Receive Timeout Error -1073807339 on VISA Read or Write?
spex
Spex
To the pessimist, the glass is half empty; to the optimist, the glass is half full; to the engineer, the glass is twice as big as it needs to be has a 2x safety factor...
(12,060 Views)
Hi Spex,
Thanks a lot for the reply.
I am using Rigol M300 Data Acqusition System. I am communicating over LAN.
I tried all the ways mentioned in the above link, but I am not able to solve this.
(12,060 Views)
