LabVIEW Embedded
fft and ifft mismatch
Hello , I have designed a simple sequence to check the ifft and fft of an array . Initially i create a set of data that is fed into the ifft block , the output that i get out of the ifft block , i feed it into a fft block . it is only fair that i expect the output from the fft block to be the same as the input to the ifft block. But , that is not how it turns out . Can anybody give me a explanation why this is the case . and i am using this with a DSP board (speedy 33) . Mano .
Message 1 of 1
(5,929 Views)
