LabVIEW Embedded
how can we store code permanent into lm3s8962 through labview arm module?
i am using labview 2012 with arm module. i got problem that i can not store the code permenent into the lm3s8962 luminary board so when i cutt off the power supply then the code got erased. so is their in setting should done in labview to store the code permenent into lm3s8962 luminary board...?
(5,881 Views)
After a build in LabVIEW you can see the code in KEIL uVision. I think that your project is already set to download it to the flash.
I think you have set the option in de LabVIEW build: enable debugging and Generate guard code.
when you uncheck them, your application wont need a kick from your debugger to start the application..
Wouter.
"LabVIEW for ARM guru and bug destroyer"
(5,721 Views)
