LabVIEW Embedded
intefacing rf transmitter and recevier with myrio
Hi.... i am trying to interface rc receiver which gives pwm signal as output to myRio.... When i vary the control in transmitter the receiver output pwm duty cycle varies.... i got a vi which will give the duty cycle of a pwm input in my daq.
i thought replacing daq assistant with myrio's analog input will give us duty cycle as output but it didn't work..... I've also attached the vi used....i am using (fs-ct6b 6-channel (transmitter+receiver)).Awaiting your suggestions and solutions.
  Thank you.
Message 1 of 1
(3,558 Views)
