LabVIEW Embedded
is it possible to develope an application in Atmel AT91SAM9263 using Labview
Hi friends,
 I have exp in labview automation but totally new in Embedded applications . I have one Atmel AT91SAM9263 EK (including touch screen disply) borad with m. is it possible to develop applications using labview. for this purpose which module we required. From where i can start. please help me for that.
thanks,
niks
(7,145 Views)
HI,all
I find a very interesting rtos CooCox CoOs , it seems to be excellent.
you can get the source code of the the Free CooCox CoOS RTOS and detailed
documents about the OS form the site .
[url]http://www.coocox.org[/url]
If you feel satisfied with the user's forum reply please click on the thank button.
Obey forum rules!
Respect others!
(7,139 Views)
HI,friends,
 I find a very interesting rtos CooCox CoOs , it seems to be excellent. you can get the source code of the the Free CooCox CoOS RTOS and detailed documents about the OS form the site .
 If you feel satisfied with the user's forum reply please click on the thank button. Obey forum rules! Respect others!
(7,139 Views)
You have multiple options:
Since, it is supported by Keil (Atmel AT91SAM9263) you can follow the LabVIEW for ARM Microcontrollers porting guide (http://zone.ni.com/devzone/cda/tut/p/id/6994). You may be especially interested how Phytec board has been ported.
Also, if you want other RTOS, you can use Microprocessor SDK and read again about Phytec (http://digital.ni.com/manuals.nsf/websearch/AB597F3FD5D9011886257448005F4A0C).
Eiso-risky:
Even if you posted two times, I shouldn't click the button because this is a ARM926EJ-S and not Cortex-M3.
Would it were a Stellaris or SAM3U ..., but where is such a button?
(7,132 Views)
Re Eiso-risky:
        Yes, CooCox CoOs is not only very new,but also has many excellent features. It's specially for ARM Cortex-M3.You can get CooCox CoOS user's guide and source code from site: http://www.coocox.org .
(6,975 Views)
