LabVIEW Embedded
lm3s1968 don't work
Hello
I have a problem with my lm3s1968 Evaluation Board. I can build and download applications to the device without problems. But the device shows no reaction! Also with labview examples. I use the EK-lm3s8962-USB target, is this the right way for my lm3s1968 device, because of other display size, other ports and so on?
Thanks in advance!
(6,948 Views)
Hi
Please see this link http://forums.ni.com/t5/LabVIEW-Embedded/Custom-hardware-and-the-ARM-module/td-p/815817
See question 3. I hope this will help you.
Best Regards
Bernhard
(6,926 Views)
Hi Bernhard
I've already saw this post, but it's not really helpful for me. Let me explain that, when I use a simple example like "blinky", I can download this to the device I can start the VI, but nothing is blinking on the device. It's exactly the same with the OLED Display. I think it is something wrong in the configuration, but I can't find the failure.
Best regards Kris
(6,918 Views)
Hi
I'm not a specialist for ARM and LabVIEW embedded, but I will do what I can and I hope I will find something in my Database
and I will ask some colleagues from me. You will hear from me soon.
Best regards
Bernhard Rennhofer
(6,900 Views)
Hi Kris,
Some of this documentation may be helpful:
ARM Devices Supported by LabVIEW: http://www.ni.com/white-paper/7066/en
Getting Started with the NI LabVIEW Embedded Module for ARM Microcontrollers: https://www.ni.com/docs/en-US/bundle/375177c/resource/375177c.pdf
LabVIEW Embedded for ARM Porting Guide - Chapter 1: Introduction: http://www.ni.com/white-paper/6994/en
Because you are not using a Tier 1 device the porting guide should be most applicable to you.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(6,884 Views)
Hi Craig
Where did you see that the lm3s1968 is a tier 2 device?
Best regards
(6,867 Views)
Hi
Follow the first link from Craig and you will see there only 3 Tier 1 devices. There are no more than this 3 Tier 1 devices. I searched for this information in the NI community.
If you want to use a Tier 2 device, so you have to follow link 3 from Craig.
Best regards
Bernhard
(6,860 Views)
