LabVIEW Embedded
lm3s8962 ping labview-tcp error?
Message 1 of 11
(9,926 Views)
Have the same problem. I am new to NI forums , just started with Labview and Arm.
Message 2 of 11
(9,860 Views)
So what was the source of such behaviour?
Message 3 of 11
(9,593 Views)
Re-read this post, currently no solution, ping labview-tcp no data is returned, the cable is good; also do not communicate through a router.
Message 4 of 11
(9,250 Views)
try:
ping "labview-tcp"
no slashes (/)
Message 5 of 11
(9,174 Views)
I had the same problem and now it's fixed.
The default complier options are to use a DHCP server. I suspect you do not have a DHCP server.
You can go to the compiler options and change the option to use a DHCP server and assign an IP address. This way you will have an IP address to use for the example program. (You will still not be able to ping "labview-tcp" as I suspect this name translation is soemthign also done by the DHCP server (or similar)).
Message 6 of 11
(9,150 Views)
also had problems to communicate between the card and the computer, I could rectify it by accessing the Project Connection prodiedades placing a static IP address
Message 7 of 11
(8,914 Views)
This procedure wishes to Ethernet data transmission between ARM LM3S8962 evaluation board and a computer, this process began when a client connection to the microcontroller, the server started generating random data and send to the client program (for this illustrative example only have paired with a client), if the client program disconnects or lost the link, the transmission stops and the microcontroller stay pending a new connection, as in previous demonstrations employ two routines the first is responsible for the generation of messages on the screen of the card and the second Ethernet communication, more https://decibel.ni.com/content/docs/DOC-35105
Message 8 of 11
(8,359 Views)
Thanks for this.Smiley Happy
Also following thread is useful: http://forums.ni.com/t5/LabVIEW/Why-isn-t-DHCP-working-on-my-ARM-application/td-p/1502728
Here are some snaps to make it more clear. ( These are also there in above thread.)
Bhaumik
Message 9 of 11
(8,256 Views)
Bhaumik
interesting, but the question is for a specific target LM3S8962, the answers are generic to a ARM microcontroller?
Message 10 of 11
(8,251 Views)
