LabVIEW Embedded
run error
I'm trying to realize a communication between an ARM LM3S8962 and a Zigbit by the UART port.
The communication works well but when I want to analyse the received message there an issue.
The program build correctly and when it's starting the target, it doesn't entering in debug mode, debugger says that there the run failed and I have this message :
Detail: [UVSC_DBG_ENUMERATE_BP,MSG: 0xC, STATUS: 0x1E](30)
Status : Run failed.
Cédric
I think there was a problem when I posted, could a moderator deleted the two other posts? Thanks.
Message Edité par cgarel le 05-04-2010 04:40 AM
(6,249 Views)
Duplicate
    Benjamin R.
Senior LabVIEW Developer @Neosoft
(6,215 Views)
