LabVIEW Embedded
samsung mini2440 win ce gpio keypad interfacing
hi i am using mini2440 samsung board support pakage (bps) using win ce 5.0 and want to interface a keypad through gpio
can i use labview 7.1 if possible then please specify the helpful material
regards
Engr. Mohazzab JAVED
Message 1 of 12
(14,575 Views)
Hi Mohazzab,
You can use the LabVIEW PDA Module to develop applications for Windows CE Devices.  Take a look at this DevZone Tutorial for more information:
http://zone.ni.com/devzone/cda/tut/p/id/4577
Message 2 of 12
(14,557 Views)
thankyou for your interest smoothatic
i get a lot of help from your  link
just tell me one more thing that can i use labview pda module for samsung mini2440 bsp (ARM-920)
Message 3 of 12
(14,546 Views)
Hi Mohazzab,
The LabVIEW PDA Module is designed to work Windows Mobile devices and not Windows CE devices.   Unfortunately, I do not think that you will be able to use the LabVIEW PDA Module with your samsung mini2440.
Justin Parker
Product Support Engineer
Message 4 of 12
(14,521 Views)
You can use NI LabVIEW Touch Panel Module, it works. But to control GPIO, you have build a dll which you can call it from NITPM.
Message 5 of 12
(14,329 Views)
Dear all..
I want to create a lab view which can be run on mini2440.
For the Lab view Application i want to use dll. which includes some basic functions.
so which programming language i have to use to create dll.
please help ..
thank you ...
sunil
Message 6 of 12
(11,020 Views)
Message 7 of 12
(11,009 Views)
Dear Marand,,
Thank you very much for your information...
Can you Do me one help.
if you know how to create serial port dll in VC++ then please help me ..
Thanks and regards
Sunil
Message 8 of 12
(10,999 Views)
Hi everyone,
Do you have any suitable driver for mini6410?
Message 9 of 12
(8,482 Views)
Hi Azmi,
Thank you for posting in the forums. For visibility, you may want to create a new forum post, since this one is a few years old. Additionally, since we don't make the mini6410, National Instruments has limited resources on how the device is able to interface with our products, but you may have better luck if you contact that manufacturer.
Tina K.
Applications Engineering
ni.com/support
Message 10 of 12
(8,461 Views)
