LabVIEW Embedded
sbRIO starting point
Hi there,
I'm currently trying to figure out how to interface with an sbRIO, I am part of a team that is trying to design a small robot capable of collecting a series of balls. the main controller code I'm ok with, however I'm not sure how to send out/recieve a signal using the sbRIO. I was wondering if anyone could point me in the right direction.
George
(6,395 Views)
Hi George,
Welcome to the NI Discussion Forums!
Could you give a little more information on what exactly you are trying to do?
  • Are you having trouble accessing the I/O of the sbRIO?
  • If this is the case, is it for the hardware of software side of things?
  • What kind of signals are you looking to interface with?
  • What model sbRIO do you have?
It is also worth noting that the architecture of the sbRIO is very similar to that of a cRIO. As such, much of the documentation for the cRIO will also be relevant to sbRIO.
A good starting point would be here: http://www.ni.com/singleboard/setup/
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(6,387 Views)
