LabVIEW Embedded
speedy-33 feedback loop
Hi, i'm using speedy-33 as my DSP target and i wish to perform a feedback loop. i tried the example found in the NI website but it shows error that the array size is mismatch. Does anyone know how the data flows? Let say when i create an analog input, it is a 1-D array. Inorder to create a feedback loop i need to create an array of known size 1st, am i right to say that?? From there onwards, wat are some of the ways that i can can my array size or when do i need to alter my array? Can anyone pls help?? Thanks
(7,346 Views)
Hi Alantino,
Thanks for your post. You are correct to say that you cannot dynamically allocate memory when using LabVIEW DSP module targets. I am not sure exactly what example you are referring to but here are some addtional details on this that may help you better understand and workaround this constraint:
How Can I Be Successful With Arrays In the LabVIEW DSP Module?
http://digital.ni.com/public.nsf/websearch/684D71E7BFD4D56C8625700E00662BF7
Why Do I Receive an Error When I Use Stacked Shift Registers in My DSP VI?
http://digital.ni.com/public.nsf/websearch/0B37248F9063664D8625700E006A9E64
I hope this helps. Thanks Alantino and have a great day!
Steven C
(7,336 Views)
Hi steven,
Thanks for the reply,
Using labview 8.2, DSP target speedy-33
Currently i'm trying to get a feed back from my sample delay function then add back to my signal to create a reverberation effect.
problem
1)the waveform i see from my waveformchart are square wave.
2)I try to set my frame size at 1024 but the programm just run for a few sec and stop.
3)my audio signal sounds like transformer singing!!
can someone help me point out where my problem lies on??
Thanks in advance.
(7,328 Views)
