LabVIEW Embedded
transform desktop VI to ARM VI
Actually it is String To Byte Array.vi.
You need the byte array to verify checksum
Message 11 of 13
(3,279 Views)
May be something like that:
Message 12 of 13
(3,276 Views)
OK, it appears you got the idea.
Just couple things:
Serial Port Read.vi is blocking the current task until all bytes arrives (if you are using only while loops then the microcontroller does nothing for 31/1920 = 16 ms). You can use Timed Loops, or check for available bytes before reading.
Checksum should be checked for each packet (e.g. inside CF case).
Also you should think about:
-what's happening if 3DM doesn't respond?
-how to handle errors (for example, a single bit error might result into a NAck from 3DM, so all the incoming stream will be different)
-etc.
Message 13 of 13
(3,260 Views)
