LabVIEW Embedded
visualdsp++ build fail?
failed to script build tools
*** compiler output ***
C:\Program Files\National Instruments\LabVIEW 8.2\examples\lvemb\Blackfin\BF533\LED Example\BF533 LED Example>"C:\Program Files\Analog Devices\VisualDSP 4.5\ccblkfn.exe" -g -c -proc ADSP-BF533 -threads -labview -implicit-pointers -I. @.\prjHeaders.lst -DCHeadless -D__vdk "C:\Program Files\National Instruments\LabVIEW 8.2\examples\lvemb\Blackfin\BF533\LED Example\BF533 LED Example\BF533_Toggle_LED.c" @.\prjOptions.lst
"..\..\..\..\..\..\CCodeGen\Include\blockdiagram\LVEvents.h", line 30: cc1661: {D} warning:
          enumeration value is greater than int type
  } LVEventType;
(7,335 Views)
mcusir:
I hope all is well. I saw that this forum has been unanswered and I am not sure about whether or not you are still experiencing this issue. Please let me know either way so that I can act accordingly.
Rudi N.
(7,313 Views)
mcusir:
In the event that you are still experiencing this issue or for future references, please check out this document. I hope it helps.
Rudi N.
(7,308 Views)
