This was implemented in change 6423854 in LabVIEW FPGA 2018. We’re using Consolas as the font for the Xilinx Log as of that release.
Xilinx log window should use a fixed-width font.
Which of these two string indicators with identical content is easier to read?
Kudos- this one is a no-brainer.
Mark this one as implemented, just tested LV 2018 and guess what......
