When working with CLIP-generated clocks we need to have good UCF files for proper compilation control (Something we now have after WEEKS of debugging ).
At the moment the ucf files MUST be in Users\Public\Documents\National Instruments\FlexRIO\IOModules for the code to work even though all other CLIP-relevant files can be located anywhere.
Please let us use the ucf file located int he same directory as the CLIP we're using otherwise we'll end up with cross-linking nightmares between users who don't have the right version in their local folder.
Shane
