It sure would be nice to take advantage of timed loops when your FPGA is dictating the timing of your host code with IRQs. DAQ and XNET can make timing sources to drive the timed loop, why not LV FPGA?
I'm imagining a "Create timing source from IRQ #" VI. # input and string output along with the reference wires.
