LabVIEW FPGA Idea Exchange
Terry_ALE
LabVIEW FPGA Host Interface
Status: New
When not using Instruction Framework to interface from the Host to LabVIEW FPGA the FPGA VI reference register items cannot be ordered by the user
They appear in a random order (order of creation) and it is not easy to find and select them.
I am referring to this function: https://zone.ni.com/reference/en-XX/help/371599P-01/lvfpgahost/readwrite_control/
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
6 Comments
rolfk
Knight of NI
It's not exactly the order of creation but the tabbing order as set in the FPGA front panel. That is of course the order you create them in the first instance but you can always go into that front panel and select Edit->Set tabbing order. The naming may sound a little unusual for the FPGA front panel but LabVIEW reuses a lot of things for all the different targets and changing the menu names based on the context while not impossible is a lot of work for something pretty cosmetic. Especially since it is not easy to come up with names for menu items.
Rolf Kalbermatter  My Blog
Terry_ALE
Active Participant
That's good to know.  Did you find this on your own or was there a source for this?  If the former, then probably would be good for LabVIEW FPGA help documentation to be updated.
What about the order of P2P or DMA FIFOs?
ALE Consultants
rolfk
Knight of NI
Have to admit that I simply assumed that this works that way as it made sense to me (I'm using the Set tabbing Order quite regularly in user interfaces). And I did use it recently in a project just like that. I have no idea if it is documented somewhere in the FPGA documentation. Most likely it is, but where in the 1000ds of pages?😀
Terry_ALE
Active Participant
This idea exchange request could be closed out.
ALE Consultants
crossrulz
Knight of NI
Terry,
Are you saying that setting the tabbing order meets your needs?
Terry_ALE
Active Participant
Yes
ALE Consultants
