Recently, Last year, i've had a bad experience, when i tried to compile my old FPGA applications with Windows 10.
=> The FPGA ISE XILINX compiler is no more compatible with Windows 10.
Will something be done ? I got no clear answer from NI support ...It should be a XILINX problem !
The issue is that some products on the NI web site, are sold without clear information about the incompatibility with Win 10 !
Please, add a "clear highlighted Warning" on the product page in order to inform about the problem : On FPGA boards and on CRIO targets ...
Thanks for help.
